Removing steering/head bearings
martinz1000r
#1 PostAuthor: martinz1000r » Mon Oct 03, 2016 1:06 pm
How do i get the lower race out the frame? Upper was no problem as there was a lip I could put a drift against but the lower race is completely flush. I dont have access to a welder before anyone recommends welding something to it to bash against.
#2 PostAuthor: chrisu » Mon Oct 03, 2016 3:06 pm
dremel ?
martinz1000r
#3 PostAuthor: martinz1000r » Mon Oct 03, 2016 3:26 pm
chrisu wrote:dremel ?
Had crossed my mind but was worried about damaging the frame
#4 PostAuthor: chrisu » Mon Oct 03, 2016 3:33 pm
cut a slot in the bearing cup and you should be able to lever out.
I've always found at least a small lip you can use to drive the bearing out.
Users browsing this forum: Bing [Bot] and 58 guests
