ZRX swinging arm, shocks, caliper or torque arm?
RussG
#1 PostAuthor: RussG » Wed Oct 05, 2016 10:11 pm
Hi, I'm after a ZRX swinging arm, to go on my Z1000, I also need a brake caliper, torque arm and adjusters if at all possible. Please let me know if you can help, thanks Russ
Charlie
#2 PostAuthor: Charlie » Fri Oct 07, 2016 4:29 pm
There is a ZRX1200 arm for sale on the ZRXOC at the mo
Just curious - what front end did you go with ?
RussG
#3 PostAuthor: RussG » Sat Oct 08, 2016 8:42 am
Thanks Charlie, I went with a ZXR front end, fitted straight on, I just had to grind the steering locking cylinder under the headstock off.
Charlie
#4 PostAuthor: Charlie » Sat Oct 08, 2016 11:18 am
Cool. I have a ZRX1200 front end to go in mine. That will also drop pretty much straight in. Just lock stops to construct and the speedo reading to correct.
RussG
#5 PostAuthor: RussG » Sat Oct 08, 2016 11:12 pm
How do you adjust the speedo reading?
Could you post a link to the one on ZRXOC please? I joined but the one I found had been baggs'd
Charlie
#6 PostAuthor: Charlie » Sun Oct 09, 2016 9:46 am
I haven't sussed the speedo issue yet. I have a couple of ideas to try though.
This was the arm for sale but it does appear to have been allocated
http://www.zrxocboard.com/board/showthr ... -SWING-ARM
