I'm looking to buy a frame bracing kit for my Z900A4 project. Has any body used the PMC or Kosman bracing kits, and if so does anyone have a price/contact for importing one of these kits. Any help much appreciated.
Steve
Frame bracing kits
Pigford many thanx for printing that AGAIN
remember it from before but could never find it
my question is this:- distortion occurs from welding,would the frame have to go in a jig so kit can be welded? or is that not such an issue? this "kit" take it its cut to spec and there are instuctions for where each component locates ?
: my question is this:- distortion occurs from welding,would the frame have to go in a jig so kit can be welded? or is that not such an issue? this "kit" take it its cut to spec and there are instuctions for where each component locates ?
I've just bought all the tubing and plate to brace my frame up for a tenner. I know that leaves me to cut and mitre all the relevant bits, but I'm notoriously tight. MIG welding shouldn't distort the frame if you do it a bit at a time. The last one I braced, I brazed all the tubes and plates in - but in hindsight that probably puts more heat into the frame than today's technology, but there were no problems with that one.
I've started to attack my frame now, and it's surprising how much weight it's lost, although it was a bugger to cut out the front flitch at the top of the downtubes. Having done that, it's probably lost so much strength that if you could put it together and ride it, it'd probably handle like a.......like a......... like an old Kawasaki:(
