Z1 73
geraldknight
Z1 73
#1 PostAuthor: geraldknight » Sun Oct 30, 2016 5:20 pm
Hi could someone tell me if any of the 1973 Z1 900s had tank badges about 186mm long with hole centres about 146mm. If not what is the thread used on the badge screws?. Also did that year have a steering damper?. Many thanks Gerald
#2 PostAuthor: z1bman » Sun Oct 30, 2016 6:48 pm
early badges where 122mm long later ones z1a/z1b 185mm long
wilsonsjw11
#3 PostAuthor: wilsonsjw11 » Sun Oct 30, 2016 6:59 pm
Tank badge screw;
Countersunk-M3 x 6 (Pt number 92012-003)
Regards
Steve
geraldknight
Z1 900 73
#4 PostAuthor: geraldknight » Sun Oct 30, 2016 7:22 pm
Thank you very much for the information. Cheers Gerald
#5 PostAuthor: Pigford » Sun Oct 30, 2016 7:40 pm
Steering damper was offered as an optional extra... the earlier triples had them; is there a bracket on the r/hand side lower headstock?
wilsonsjw11
#6 PostAuthor: wilsonsjw11 » Sun Oct 30, 2016 7:58 pm
Pigford wrote:Steering damper was offered as an optional extra... the earlier triples had them; is there a bracket on the r/hand side lower headstock?
Bracket for the damper is on the frame and the other end fixes to the bottom steering yoke via an M8 clearance hole.
Regards
Steve
geraldknight
#7 PostAuthor: geraldknight » Sun Oct 30, 2016 9:46 pm
yes there is a bracket & M8 hole to allow for a damper but i wasnt sure if it is meant to have one. Cheers
Users browsing this forum: No registered users and 111 guests
