Wanted; laser down pipes to replace mine. (whats the chances???) Just discovered mine have a crack in one pipe (half way round) where it meets the collector and probably too frilly to weld even if i did cut it open. Its down between the pipes as well!
The end of the link pipe is 68-69mm for a 70mm laser silencer which i am doing all that i can to keep for several reasons inc. noise test, baffle changes and physical size. That and the fact that i have two identical silencers.
Photos' to follow when photobucket sorts itself out.
Laser 4 into 1 downpipes
Eyup Al,
Could you butcher this fellow, maybe chopping it off just after the collector and welding yours to it?
http://www.ebay.co.uk/itm/kawasaki-gpz1100-a-full-neta-exhaust-system-unitrak-/162232329893?hash=item25c5cce6a5:g:TNYAAOSwgmJX0Xhy
Or, what about a set of Delkevic downpipes?
http://www.ebay.co.uk/itm/Stainless-Steel-Downpipes-Header-Exhaust-Manifold-GPZ1100-Uni-Trak-ZX1100A-83-85-/291706726925?hash=item43eb136a0d:g:LzsAAOSw5ClXx0XF
Julian_Boolean
