Fuel Reserve
Fuel Reserve
Can anyone tell me the total fuel capacity for my 1979 Z1000 A2 - Also at what level does the reserve kick in ? Thanks all.
16 litres I think is the fuel tank capacity for the A2. Reserve is around 2-2.5 litres.
It's actually closer to 17 litres
Working on roughly 9-10 miles to the litre I used to get around 110 miles on main which would suggest nearly 5 litres on reserve. This was an A1 which has the same capacity tank but different tap.
Of course all of this depends on the fuel tap pick up height.
- Mark Tiller
Hi Mark,
On a single pingel it is not very much at all and I am not sure how consistent they are - I have seen one person say like under 10 miles - I have done 20 careful miles on reserve and when filled up I calculated that there was very very little left to go - always meant to run it dry to really tell ....!
I do have a slightly tuned engine and larger carbs so using more than a standard bike.
Others I am sure can advise further.
