outrigger sprocket bearing holder plate - vendors of choice?
#1 PostAuthor: chrisu » Mon Dec 12, 2016 5:14 pm
The current slave cylinder on my Z1R is a of uncertain origin and leaking. i've had a few suggestions as to what it might be but not found a match in real life yet. The existing cover has been modified specifically for this slave cylinder.
so........
I was going to go for an outrigger plate as i also have a 530 offset sprocket which needs an outrigger bearing capability. I can then (hopefully) mount the new Falk slave cylinder i have.
Whats the current plate of choice ?
#2 PostAuthor: Ginger Bear » Mon Dec 12, 2016 5:38 pm
Chris, I have a Kosman fitted to mine, not sure where to source a new one though. :??
Neil slappa13 might be able to help, or Zomerset Zed was cnc'ing his own.
slappa13
#3 PostAuthor: slappa13 » Mon Dec 12, 2016 5:46 pm
I use d&g chassis outrigger plate very well made and not too expensive
#4 PostAuthor: Pigford » Mon Dec 12, 2016 5:56 pm
slappa13 wrote:I use d&g chassis outrigger plate very well made and not too expensive
+1 .... fitted one on my MkII drag bike a while back :wink:
#5 PostAuthor: chrisu » Mon Dec 12, 2016 6:19 pm
thanks - Neil is sorting one out for me.
