rear light
bunnysZ
Granny Magnet
rear light
#1 PostAuthor: bunnysZ » Tue Dec 27, 2016 11:21 am
been moving indicators on rear and taken tail piece off to be re-sprayed etc, when putting it back the rear light is now not working, i have changed the bulb, checked the elements, all ok, checked the wires no loose connectors found,
brake light works but not the normal tail light, ay suggestions.
#2 PostAuthor: z1bman » Tue Dec 27, 2016 12:14 pm
have you checked the fuse?
slappa13
#3 PostAuthor: slappa13 » Tue Dec 27, 2016 12:17 pm
Hi bunny, I had the same problem when I took my zed to mot, no rear light, changed bulb still not working, it was a loose wire behind the side panel after spending hours stripping wiring loom
