GPZ J type RH switch cover
Gus
#1 PostAuthor: Gus » Tue Jan 03, 2017 9:27 pm
Evening gents.
I'll get straight to the point, I'm on the scrounge.
Does anybody have a knackered RH switch which I could have the cover that holds the throttle cable in place in the switch housing?
The cover uppermost in the pic held on by the uppermost screw.
I've lost mine and even got arrested so I could have a cavity search and still couldn't find it :roll:
Gus
"Set the GRINDER on it"
Julian_Boolean
#2 PostAuthor: Julian_Boolean » Tue Jan 03, 2017 9:47 pm
I've got a whole right hand switch you can have or I can just send you the cover.
The switch is tatty and has electrical issues.
Gus
#3 PostAuthor: Gus » Tue Jan 03, 2017 10:54 pm
Hi Julian.
Excellent.
PM sent.
I don't need the switch as I had to make repairs to the one I have and it has tested OK and fitted.
Gus
Gus
#4 PostAuthor: Gus » Tue Jan 24, 2017 7:42 pm
Thank you to Julian for sorting me out.
Gus
Julian_Boolean
#5 PostAuthor: Julian_Boolean » Wed Jan 25, 2017 7:06 am
No worries, it was only going to be binned
