Hi I am after a z1100r gear lever knuckle, the part that goes on the shaft and clamps with a single bolt .
I believe the 1000r and GPz A,s are the same thanks jez
Z1100r gear leaver knuckle
if its the rose joint that's worn? grind of the weld & buy a new rose joint
http://www.ebay.co.uk/itm/M6-Female-Tra ... 3641.l6368
