New to site looking for parts
Highlander
#1 PostAuthor: Highlander » Fri Feb 24, 2017 2:36 pm
Hi folks I am new to this Forum
I am looking for the following parts for my Z1000 A2 if anyone can
Point me in the right direction I would be most grateful.
Fuel Tap.
Headlamp glass.
Set of engines protector bars
Cheers,
Highlander
Highlander
KWACKERZ1
#2 PostAuthor: KWACKERZ1 » Fri Feb 24, 2017 2:52 pm
Welcome try zpower or z1enteeprises or saisei you a web search will find rhem or the links section above.
G
#3 PostAuthor: G » Fri Feb 24, 2017 3:06 pm
Welcome on board
8 Valve Mark
wtd
#4 PostAuthor: 8 Valve Mark » Fri Feb 24, 2017 6:38 pm
welcome highlander, try breaking point in Torry,aberdeen for a headlight (h4 best) and eBay/z-power as already mentioned. mark
Highlander
#5 PostAuthor: Highlander » Sat Feb 25, 2017 12:13 am
Thanks for the advice, will try the sources mentioned
Highlander.
Highlander
Kev1R
#6 PostAuthor: Kev1R » Sat Feb 25, 2017 10:05 am
I had problems with the original fuel tap which is of vacuum type
I found there was still a small weep of fuel from the tank when there should be nothing.
This might sound minor but you can end up with a cylinder full of petrol which the engine will try to compress on start up. - Potentailly a lot of damage.
I tried a refurb kit for the tap but it was still not 100%.
I ended up fitting a pingel adapter to the tank and then obtained the earlier type fuel tap (From John Browse Wrexham) with the more straightforward on-off- reserve arrangement - It has been fine since then.
Kev
010
Highlander
#7 PostAuthor: Highlander » Sat Feb 25, 2017 11:17 am
Yes Kev, that's the problem with my one. Tried a referb kit but that was as much use as a hole in a parachute. May just have to bite the bullet and buy a new one from Z power, but its difficult when you are as tight as I am.
Highlander
Kev1R
#8 PostAuthor: Kev1R » Sat Feb 25, 2017 1:47 pm
Be wary of replacement fuel taps - There is some discussions on this site where people have bought replacements which have been poor quality.
There was talk of some new ones about to hit the market in 2015/16 - from Z1 enterprises which they had high expectations
Maybe Saisei (supplier and site contributor) can advise the latest.
Pingel seem to be rated highly but they look abit odd (to me!) on a 70's bike.
010
Z1Scot
#9 PostAuthor: Z1Scot » Sat Feb 25, 2017 5:47 pm
Hello,if not bothered about originality,old style mini headlamps are straight fit into headlamp rim. And are available without sealed beam. I got fuel tap and engine bars from Z Power. No problems with tap. And bars fitted perfectly :D
Neil Anderson
Highlander
#10 PostAuthor: Highlander » Sat Feb 25, 2017 6:30 pm
Great advice folks, Thank you so much.
May meet some of you a the scotish motocylce show on the 11th March if your about. or staford later in the year.
Highlander
8 Valve Mark
stuff
#11 PostAuthor: 8 Valve Mark » Sat Feb 25, 2017 7:37 pm
hope you got sorted ok. maybe see ya on the 11th,i got a ticket to see rangers getting fucked again on the 12th in a kawasaki green N white styleee...Kork ballington..
LeeJackson
#12 PostAuthor: LeeJackson » Sat Feb 25, 2017 11:16 pm
Welcome Highlander. Far a boots in the highlands r u?
Highlander
#13 PostAuthor: Highlander » Mon Feb 27, 2017 3:13 pm
Inverness Lee. on the shores of Lochness.
Highlander
000zeds
#14 PostAuthor: 000zeds » Mon Feb 27, 2017 5:47 pm
Inverness is my favourite place in Scotland :D :D :D
Zeds-R-Us
Highlander
#15 PostAuthor: Highlander » Mon Feb 27, 2017 7:25 pm
Thanks for all the welcomes, kettle is always boiling if you are passing. on a Z
Highlander
