GPZ1100 B1 FUEL TANK
felix
#1 PostAuthor: felix » Sat Mar 04, 2017 2:18 am
as above cash waiting
mattc
Re: GPZ1100 B1 FUEL TANK
#2 PostAuthor: mattc » Tue Mar 07, 2017 6:31 pm
Hi, I have one happy to move on.
jovin04 was looking for one and I was chatting to him about it. I have not heard anything for nearly a week now so if interested pm me.
Cheers, Matt
Matt C
felix
#3 PostAuthor: felix » Sat Jun 17, 2017 11:40 pm
Hi mate do you still have the b1 tank and how much are you after for it.
cheers Ian
mattc
#4 PostAuthor: mattc » Sun Jun 18, 2017 4:32 am
Yes I do. I have sent you a pm
Matt
Matt C
mattc
#5 PostAuthor: mattc » Mon Jun 19, 2017 6:08 pm
Hey Ian, I did send you a pm.....did you not get it?
Matt
Matt C
rickm
#6 PostAuthor: rickm » Thu Aug 17, 2017 11:51 am
Hi,
Is this tank now sold?
If not, then what condition is it, and does it come with fuel tap & level sensor?
Ricky
H2B GPZ900R
mattc
#7 PostAuthor: mattc » Thu Aug 17, 2017 12:13 pm
Not sold Ricky....I never heard back from previous interested party.
The tank has no good fuel taps although I might have one or two knocking around that could be cleaned up. It looks like the tap position on the RHS has been moved forward at some point in the past.
It needs a round base fuel sender not the elongated version. I "might" have a dubious one somewhere if you cannot get anywhere else.
Tank does not leak I am pretty sure as it was on a non-working bike I bought on ebay with a weird oil/fuel mix in it for 12 months.
The inside would need a good clean out.
Matt C
rickm
#8 PostAuthor: rickm » Thu Aug 17, 2017 12:40 pm
I actually have a 1000J with the US style tank at the moment.
Odd, but when I had a J back in the day I always preferred the rounder US version tank, but now I'm not so sure!
Presume I'd just need to blank off the fuel return hole to fit it on the standard carb J model?
Can you PM me a price?
H2B GPZ900R
mattc
#9 PostAuthor: mattc » Thu Aug 17, 2017 1:54 pm
To use on J with carbs you would need to check whether the fuel tap mounting (that looks like it has been moved) is still in the right place...or move it back. When I bought this tank on a bike, it just had a bolt plus fibre washer blanking off the return hole. The fuel tap on my J has the elongated hole for the filter and two M6 bolt holes that goes with the vacuum tap. You could use the B1 style tap that does not have the vacuum control. A number of options really....use a pingel....etc
If I have a fuel sender it will probably be a bit corroded and need new wiring and clean up as a min.
I will have a look tomorrow
Sending pm re the price
Matt
Matt C
rickm
#10 PostAuthor: rickm » Thu Aug 17, 2017 3:03 pm
Replied :up
H2B GPZ900R
tlc
#11 PostAuthor: tlc » Thu Aug 17, 2017 6:11 pm
I have a skanky one I'm looking to shift.
rickm
#12 PostAuthor: rickm » Fri Aug 18, 2017 6:25 am
Thanks, but I've done a deal for the tank with Matt now.
Do you have any of the accessories? (fuel tap, filler cap, gauge sender, badges, etc)
H2B GPZ900R
rickm
#13 PostAuthor: rickm » Fri Aug 18, 2017 6:30 am
Matt,
Like the spec of your J2 :up
Did the 1105 pistons go into a bored out J block, or did you need a GPz one?
I ended up putting GPz pistons in my original J (back in the 80s) after I managed to seize the oil scraper rings on the 2 middle pistons during a spirited ride !
H2B GPZ900R
tlc
#14 PostAuthor: tlc » Fri Aug 18, 2017 8:07 am
It has the tap, return and sender but that may be 100% of the value of the tank.
mattc
#15 PostAuthor: mattc » Fri Aug 18, 2017 8:19 am
I used the standard block from the J to go to 1105cc.
I think if you want to bigger then you would probably need the 1080cc block off the GPz1100b1
Matt C
