Replacement fuel tap.
Can anyone advise on a good gravity fed replacement fuel tap. Not pingel as they are too expensive. I am looking for aftermarket tap with 44mm centres for z650. Any ideas? Thx
Re: Replacement fuel tap.
Sorry, but I don't know of any other than Pingel.
Service the one you got?
If you need higher flow and don't need reserve solder pipe into alloy boss to fit same centres as z650
Good luck
Drew
Good luck
Drew
Thanks for the replies. Apparentky gpz900 fuel tap has 44mm fittings, so i am going to try one from flee bay
tour max taps are good quality as good as oe at least.
