Electrics
becker
Electrics
#1 PostAuthor: becker » Sat Mar 18, 2017 12:01 pm
Took the headlight/clocks off the front of my Z1000 recently - cleaning and repairs. Labelled all the wires. The bike has no indicators and there is no wiring for them from the idiot lights.
Started to put everything back together and can not get any life out of anything - starter, horn, lights, etc - would have thought something would show some life?
Battery is charged and putting out 12v and fuses are all good.
There is 12v incoming to the ignition switch and outgoing when turned on.
Have been studying the wiring diagram and all looks to be in place, but patience with auto-electrics is not my strong point :twisted:
Any tips on where I look now? reg/rec faulty?
Thanks in advance.
When life hands you lemons, reach for the vodka.
Z1B (in Z1A colours), Z1000A1, ZRX1100 C4, Suzuki TS125J (being restored), Suzuki T125J (in boxes), Garelli Rekord MKII (awaiting restoration), most of a Garelli Rekord MKI
martinz1000r
Re: Electrics
#2 PostAuthor: martinz1000r » Sat Mar 18, 2017 12:39 pm
Do you still have the original glass type fuses? I had exactly the same on my Z900 and we could not work out why nothing worked. Turned out that the wire inside the main fuse had come away at one end due to vibration. It was still touching the case so was showing continuity but could not carry a load. We only spotted it because the fuse box got moved and i saw it arc. Long shot but could be a very simple fix. Fuse box now replaced with modern version and blade fuses.
becker
Re: Electrics
#3 PostAuthor: becker » Sat Mar 18, 2017 3:37 pm
Thanks, had put a new fuse in, just in case.
Seems odd I have power at the ignition in and out (when turned on) - yet nothing anywhere else?
PAULJAC47
Re: Electrics
#4 PostAuthor: PAULJAC47 » Sat Mar 18, 2017 3:42 pm
Poss earth/ earths missing or bad ,check you have good earth to frame, engine and headlamp cluster.use a length of cable from your batt neg to short to frame,engine etc..
Re: Electrics
#5 PostAuthor: z1bman » Sat Mar 18, 2017 4:03 pm
double check you have connected the correct female block connectors to the correct males & check the wiring colors at either end
becker
Re: Electrics
#6 PostAuthor: becker » Sat Mar 18, 2017 6:33 pm
PAULJAC47 wrote:Poss earth/ earths missing or bad ,check you have good earth to frame, engine and headlamp cluster.use a length of cable from your batt neg to short to frame,engine etc..
Cheers, thats a new idea I can try tomorrow
becker
Re: Electrics - sorted :)
#7 PostAuthor: becker » Sun Mar 19, 2017 2:46 pm
Thanks for the tips lads - but got the bastard - a dodgy solder joint on the back of the ignition switch - sometimes it was good, sometimes not - resoldered and back in action :D
