900a4 parts wanted
swampy
900a4 parts wanted
#1 PostAuthor: swampy » Sat Apr 08, 2017 3:44 pm
Hi chaps
the following has been lost, misplaced during rebuild process so could anyone help me out with these.
NEEDED
chain adjuster blocks x2
rear engine mount brackets both
swing arm spindle nut and washer
hears hoping thanks guys
8 Valve Mark
Re: 900a4 parts wanted
#2 PostAuthor: 8 Valve Mark » Sun Apr 09, 2017 12:57 am
I've got 2 standard chain adjuster blocks i could part with if it helps you out,
also got 2 nice quality chromoly chain/rear spindle adjusters n matching tapered bolts to suit.only needs 2 lock-nuts (stainless)to look ace!! I'd rather sell all together really,n can post. let snow..mark 07510-529545. call/txt ok..ride safe
