hi folks has anybody used one of these kits http://www.ebay.co.uk/itm/271728331508? ... EBIDX%3AIT
cant find z1100r on the website the link takes you looking at a 530 conversion
chain and sprocket kit
Re: chain and sprocket kit
Hi thank you but that is a 630 I want to do a 530 convertion
The 530 chain conversion used to be explained well on the Z1 Enterprise Site.
I've used it often..
For example with the 530 chain for a Z1.... The rear sprocket is 42T and the front is 18T with a chain length of 110 links.
Whereas, the normal Z1 630 chain has 92 links with rear sprocket 35T and front sprocket 15T.
Also, the 530 chain comes in the o-ring type. if wanted.
RegardZ
RegardZ
Thanks I have ordered a set from debbens
