Hi, I have a set of 6 pot calipers off a ZRX to fit to my ELR. I have measured all the pistons as two per caliper are supposed to be smaller, mine are the same size.Can anyone shed some light on the matter.
Cheers Rob
Tokio calipers-piston query
Chris, the problem I have is that all the info, for the calipers state that they have 2 small pistons and 4 large pistons per caliper. I however have measured them and have found that they are all the same size. As I am trying to get a seal kit for them, I wondered if anybody else had such a problem and managed to find a solution to it.
The part no on the calipers is 1660 and 1661 and the diameter of the pistons is approx 27.00 mm.
Cheers Rob
Cheers Rob
Chris, I have checked the EBC catalogue to find which pads match mine and for a short period it looks like that two types of calipers were supplied for the ZRX 1100/1200 at the same time. Wemoto and Kawasaki only show the seal kit for the one with the small pistons, so I will have to go to the local Kwack dealer to short this one out.
Cheers Rob
Cheers Rob
Here is an update on the brake saga, the calipers fitted seem to be off a ZX6R G/J, although the chap I got them off, along with wheels and forks, reckons they are off a ZRX 1100. Checking the EBC catalogue the ZX6R pads FA188 are also fitted to the ZRX 1100, checking Wemoto, the seal kits are different, 1 having the small pistons, the ZX6R having all large pistons, cofused I surely am.
Rob
Rob
