4 main terminal blocks
I need to replace the four coloured terminal blocks on a customers Z1R-TC as they're held together with cable ties!
I'm talking about the white, blue, brown and green connector housings beneath the LH side panel.
I've done a search and it looks like Z-Power and VWP no longer offer them.
Can anyone help please?
Will
Will
- paul doran
Re: 4 main terminal blocks
Will I should have I am off tomorrow so I will take a look
Thanks Paul. It's actually the female sockets I need; namely the brown socket from the main harness and the white socket from the rectifier, so the link harness that Z1Bman posted won't do unfortunately.
I will post a picture later.
Regards Will
Regards Will
I have tried all over to find the female plugs. So far to no avail
Are these any use?
https://goo.gl/dVBXhJ
2006 ZRX1200R
1982 Z400J project
ex owner of Z1100R
GXI 2752 are you out there?
1982 Z400J project
ex owner of Z1100R
how good do they need to be and do they need the wiring attached ?
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
I searches in vain for them will, could not find anywhere, if you find any let me know please.
KeithZ1R wrote:how good do they need to be and do they need the wiring attached ?
They just need to be unbroken. I can easily remove the terminals so no wires needed. Hope you can help, just need the brown and white female socket housings. Thanks
Any good to you Will? -
http://www.ebay.co.uk/itm/Kawasaki-Z900 ... Sw7XZXg7Wp
you need to get a scrap or used harness & rectifier with good block connectors other than buying new you will struggle to find them
- paul doran
Big Fluff wrote:KeithZ1R wrote:how good do they need to be and do they need the wiring attached ?
ive some somewhere
Keith
mistaken.
mistaken.
