HI, I have a1978 Z1000 A2 which is flooding and the last owner had the same problem. I have cleaned the carbs and reset the float heights and it seems fine but give it a bit and it does it again. Seems to come out the overflows on the centre two carbs and also the inlet where the air filter fits on. The bike is a usa import and the 28mm carbs have two brass breather outlets and two lower plastick tees for fuel inlet. Also four adjustment screws underneath, not on the float bowls tho but closer up to the block, strange. (the carbs on my old Z1R 1978 were not like these)
Any thoughts ? maybe I need to try again with the cleaning.....
Be nice to just get another set nice easy Z1R carbs and just fit them !
Z1000 A2 Flooding
