73 Z1 COMPRESSION VALUES
What's the range of acceptable compression values for a 73? What should I be expecting best case? ta
- RALPHARAMA
After talking to those who really know their onions eg Steve Debben, apparently compression tests aren't all their cracked up to be, and often give false readings. My bike was smoking like a bastard and drinking half a litre of oil for every tankful of motion lotion, yet had really good results from the compression tests. Apparently a better test is the 'dropdown' test where you essentially put some compressed air into the cylinder and how much escaprtes over a specific time gives you an idea of what condition the engine is in. I fully intend to make up a rig for this test myself
Ralph Ferrand
