Old meets new...
Coose
Old meets new...
#1 PostAuthor: Coose » Mon May 22, 2017 5:16 pm
I'm in the middle of a job in Dublin which has turned into the job from hell. So, knowing I'd need to go back this week (flight booked for tomorrow) I decided to duck under the radar today, do the work bits I needed to this morning and escape out at around lunchtime. I didn't have masses of time as I had to collect a small boy from school, but it at least gave me the chance to burn a lot of super-unleaded and a little oil... :wink:
I stopped off for a quick mug of tea, and as I was about to leave the old Zed made a new(er) friend... :)
Coose
Re: Old meets new...
#2 PostAuthor: Coose » Sat May 27, 2017 8:37 am
It was certainly a cracking night for it last night, let's hope the weather stays like this for the Yorkshire Rally! :D
The old bus is properly flying at the moment, though still knocking from the cam bearings when it's warm and has sprung another leak from one of the seals behind the sprocket cover. To be fair, I've had the seals and gasket for at least a year but didn't bother changing them as I was going to rebuild the motor last winter. Damn you time thief! :wink:
I just need to sort the fork springs now, though they feel reasonable with 10psi in them but they're of course not right.
doebag
#3 PostAuthor: doebag » Sat May 27, 2017 2:57 pm
My own personal old meets new. Both shaft drive tourers separated by nearly 30 years.
'Dying a'int much of a living, boy'
Outlaw Josey Wales
Member No. 555
#4 PostAuthor: Al » Sat May 27, 2017 10:28 pm
Coose where does youre crankcase breather vent to?
One of the advantages of an airbox is it provides a constant negative pressure at the CC breather exit.
Great to hear its flying though.
Coose
#5 PostAuthor: Coose » Sun May 28, 2017 8:01 am
Al wrote:Coose where does youre crankcase breather vent to?
Straight out of the rear right corner of the bike Al, between the reg. plate and the number board.
I bought an eSkip catch tank to go in between but it weighs a ton and won't fit in the space I'd like it to go.
I'll come up with something once I get around to it.... :wink:
#6 PostAuthor: Al » Sun May 28, 2017 8:10 am
Its definitely breathing too, not gummed up with emulsion?
Coose
#7 PostAuthor: Coose » Mon May 29, 2017 4:53 am
No emulsion Al, I only fitted it tuther week.
The seals behind the sprocket cover have been there since I've had the bike so I've been expecting it really... :wink:
But, I will double-check to make sure that the breather isn't nipped anywhere.
