Looking for a 'Plate-clutch Operatin' as its called on CMSNL.
(The plate on which you mount all the clutch pressure plates and steel plates.)
On trying to remove mine,Fuckwit me bolted an aluminium bar onto2 of the clutch spring mounting points to act as a break against the 30mm socket I was using to undo the main nut holding everything together. Of course,the 2 mounting points snapped off on the first try. Leaving me in the market for a 'Plate-clutch Operatin'
Price inclusive postage to Amsterdam. Thanks.
KZ1000CSR Clutch
- paul doran
Users browsing this forum: rpeters and 41 guests
