Z1b
Z1B
Hello, this is my 75 Z1B, engine no 083624 frame no 83308, was a black motor but started to peel so stripped the motor and vapour blasted the paint off, so done the valves , guides and rings while apart. This is not a show pony and i have tried to show the blemishes in the photos but is a very original bike, the silencers are kawasaki but i know one is from the A4 model , the rear rim is pattern DID and the petrol tap, of which i have the original and also the uk rear mudguard, but apart from that i think the rest is as it was built but no expert . This bike is used as it should be with no faults and will cruise all day or see off some newer machinery whatever your choice, does not burn oil and ticks over like a sewing machine,well maintained and wants for nothing , will only increase in value and can still be enjoyed, if interested my no is 07920507260, £12,500 firm, many thanks for looking.
- paul doran
Re: Z1B
Good luck with the sale
Z1b
Just a few more photos to accompany my previous add, photography skills not a strong point as you can see, price is £12, 500, regards Jim
- paul doran
