Sprocket cover allen bolts
As title, just the sprocket cover bolts please.
Re: Sprocket cover allen bolts
Jay, you might as well just go to your local bolts /fasteners suppliers. I use 'bapp for bolts' up here and they stock almost everything you might want (everything is not always in stock). Including cap heads in stainless for literally a few pounds for a big handful. Last year I went down with a big shopping list of sizes and quantities I wanted, which ended up filling a small carrier bag for £20.
Cheers freddy
Cheers freddy
freddyz1r
PUM 329
freddyz1r
PUM 329
I don't know the lengths I want as I don't have the originals.
needaz1100r
- ZedHead
Jay1969 wrote:I don't know the lengths I want as I don't have the originals.
Put a screwdriver through the hole in the case to measure the depth of the hole, and add on 10-15mm.
An allen bolt length is from the base of the head, i.e. where it presses on the case, to the end of the thread.
A countersunk bolt is from the top of the head, but that won't concern you with these.
Cheers,
Mark.
Mark.
Cheers Gus
needaz1100r
- ZedHead
I appreciate all the input, thanks
needaz1100r
- ZedHead
Jay1969 wrote:I appreciate all the input, thanks
It wasn't a dig matey
Cheers,
Mark.
Mark.
