Flat spot
paulstrees
Flat spot
#1 PostAuthor: paulstrees » Wed Mar 05, 2008 7:01 pm
Anyone had a problem with a flat spot when you change down and then pull away at low revs ( I've been told this is common on the z900 and z1000 72-78? )
Paul
z1000Chris
flat spot
#2 PostAuthor: z1000Chris » Fri Mar 07, 2008 7:16 pm
Yes, I've got a flat spot on my z1000 when coming off idle, cant get rid of it, thinking about getting the carbs sonically cleaned :(
bunnysZ
Granny Magnet
#3 PostAuthor: bunnysZ » Fri Mar 07, 2008 7:22 pm
fuel carb problem maybe as chris says , take them off good them a clean, buy some new jets. its a matter of checking things one by one, fuel electrics, ignition etc
