Clutch hub nut
Wrigers
Clutch hub nut
#1 PostAuthor: Wrigers » Tue Jun 20, 2017 9:02 am
Hi chaps, I'm I going the right way with anti clockwise to remove the clutch hub nut. It's being a real cow to get off.
Re: Clutch hub nut
#2 PostAuthor: z1bman » Tue Jun 20, 2017 10:15 am
yes anti clockwise
Wrigers
Re: Clutch hub nut
#3 PostAuthor: Wrigers » Tue Jun 20, 2017 1:52 pm
Cheers!!!!!
Re: Clutch hub nut
#4 PostAuthor: Pigford » Tue Jun 20, 2017 2:56 pm
Rattle Gun is the way forward!
johny brando
Re: Clutch hub nut
#5 PostAuthor: johny brando » Fri Jun 23, 2017 11:24 pm
Wrigers wrote:Hi chaps, I'm I going the right way with anti clockwise to remove the clutch hub nut. It's being a real cow to get off.
There a High torque poundage item & off course Dynamic too which makes it harder & difficult to break the initial bite on them ! Assuming the motors in the bike ! Put the gearbox in gear & hold the rear brake lever fully down hard & try a long extension bar on the socket handle first if no good - try & get a Rattle gun connected to LARGE Volume receiver tank ...then use the rattle gun in reverse mode. Failing that....... you'll need the Clutch Centre to Clutch Outer 'holding tool ' BUT I found with my EBC ( part # CT-01 ) one of those ......that I had to make an offset in the handle & then weld a 300mm extension on it to be able to arrest & retain the required counter down force needed whilst using a socket & extension breaker bar.... or a Rattle gun . Hope this helps . Cheers ,Johny B
Wrigers
Re: Clutch hub nut
#6 PostAuthor: Wrigers » Sat Jun 24, 2017 1:21 pm
Thanks Johny, after two days of cursing and using all the the extention bars, anti seize lubricant etc, i borrowed a 18v impact driver of a mate and the thing flew off. I must invest in one of those, have used it since on other tight nuts and it makes mince meat out of them. Paul.
