Z900/Z1000 71mm Wiseco forged pistons
For Sale 71mm Wiseco forged pistons, light damage from spark plug failure to one piston, will clean up fine very little use before hand, come from a oversized thou block. £50+p&p
Re: Z900/Z1000 71mm Wiseco forged pistons
Hi mate, may be interested in the Pistons if they are still available, what rings are fitted XA or XC ? is there an A or C stamped on the top of the piston crown l cant make it out. lf you give me a contact number perhaps l could ring you. Thanks Paul .............................
Click on the picture to enlarge, its XC
foz
foz
Thanks foz.
Sold to Ode lad
