Couple of wiring questions
A few questions, come on Paul, z1b man, first, the little L shaped bracket that holds the brake relay , where does it fit, also the black wire from the rectifier where does that connect to, battery? Finally does the twig like diode still be fitted to a new relay? Cheers
Re: Couple of wiring questions
the brake light relay fits to the front bolt on the left hand coil . the black wire goes to the negative side of the battery .if you have not got the hazard relay fitted you can discard the diode on the flasher relay but you will need it in place if you do have hazards as it prevents back feed to the indicator relay when the hazards are turned on
Thanks Paul, that's answers my questions, I have puzzled over where that little bracket fit, I would never have thought it was there, cheers.
