Voltage Drop Question?
#1 PostAuthor: Pigford » Wed Jul 26, 2017 6:38 pm
Not related specifically to a Zed :oops:
My latest project (1980 Guzzi 850) is being a pain.
I have just fitted a h/d battery (replacing an older decent one) and still have a voltage drop issue.
The wiring is okay - there is a good +12v across the whole system including complete spark system.
When the starter is operated it spins nicely, but the voltage to the ignition (Lucas Rita) drops to just 10v :evil:
Lucas Rtia works well but needs the full 12v to work as it has a long dwell period, plus its 1980's technology!
Any idea's why the voltage drops so much - the new battery has 300CCA power and is fully charged - did it on older 190CCA battery too!
Re: Voltage Drop Question?
#2 PostAuthor: z1bman » Wed Jul 26, 2017 7:13 pm
does it have a bosch starter motor fitted ?
#3 PostAuthor: Pigford » Thu Jul 27, 2017 3:47 pm
No - Valeo
#4 PostAuthor: z1bman » Thu Jul 27, 2017 5:27 pm
i would have suggested the Valeo as the Bosch starter is known to draw more current but to be honest a 2 volt drop when cranking a twin is not that much . is it have problems starting ?
#5 PostAuthor: Pigford » Thu Jul 27, 2017 7:54 pm
z1bman wrote:i would have suggested the Valeo as the Bosch starter is known to draw more current but to be honest a 2 volt drop when cranking a twin is not that much . is it have problems starting ?
Yes, the Lucas Rita system needs the 12v to fire - it has a long dwell sequence and 10v doesn't do it :roll:
Thanks for your input by the way!
walshyco
#6 PostAuthor: walshyco » Fri Jul 28, 2017 2:37 pm
Piggy how much current is the starter motor drawing ? Is it a new starter motor if it is drawing too much current you will get a volt drop.
#7 PostAuthor: Pigford » Fri Jul 28, 2017 3:28 pm
walshyco wrote:Piggy how much current is the starter motor drawing ? Is it a new starter motor if it is drawing too much current you will get a volt drop.
Hi - the starter looks original...... it's earthed well but had been standing a few years - wondered if the brushes could be shitty or the solenoid contacts dirty?
Not sure if I can check current draw with a basic meter???
Users browsing this forum: No registered users and 93 guests
