Front Master Cylinder Z1a
BigZCas
#1 PostAuthor: BigZCas » Mon Jul 31, 2017 6:03 pm
Want to get this black anodized but not sure how to remove the innards :?? ?
I have dismantled all except for the bit inside
Can anyone advise please
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
marmck
Re: Front Master Cylinder Z1a
#2 PostAuthor: marmck » Tue Aug 01, 2017 6:35 am
Is this what you need? viewtopic.php?f=4&t=40707
BigZCas
#3 PostAuthor: BigZCas » Tue Aug 01, 2017 6:43 pm
No, it's the insides.
I will have a go at following the Haynes manual later in the week.
Past 5 Years
1976 KZ1000a1, Red
marmck
#4 PostAuthor: marmck » Tue Aug 01, 2017 6:48 pm
Have you tried YOU TUBE
swampy
#5 PostAuthor: swampy » Tue Aug 01, 2017 6:54 pm
You will need a set of right angled internal circlip pliers with very thin legs. You will also need a dowel of some sort to help pkoe the piston out from the banjo end if stiff.
Take a pic of the sequence the piston and gubbins come out. Then buy a new piston kit for the master cylinder for the reassembly. Do not attempt to use the old one.
BigZCas
#6 PostAuthor: BigZCas » Tue Aug 01, 2017 7:03 pm
Past 5 Years
1976 KZ1000a1, Red
Users browsing this forum: Google [Bot] and 75 guests
