Larger oil cooler
Larger oil cooler
I'm looking for a larger oil cooler with pipe for my z1100r. Anybody got anything before I look on eBay.
Re: Larger oil cooler
What size cooler you after
Not sure really. Something that is going to do the right job and not to ugly.
I have a 13 row cooler on my bikes. It's quite an expensive job all in though as you'll need to change the take offs, lines (with appropriate fittings) and cooler plus buy a mounting bracket. Earl's is the name most gravitate to but they are mega expensive. I use Mocal or Setrab. Slightly cheaper but good quality. Talk to Dave at Saisei as i think PMC do a complete kit.
If you go down the 13 row route i do have a KipKawa Z1000S mounting bracket I'd part with. Bolts to frame where horn mounts go and at the bottom uses original cooler mounting points. Looks just like Eddie's!!
Users browsing this forum: Google [Bot] and 30 guests
