Can anyone help or recommend someone ?
I would like my Z1a engine stripped and the Head and Crank Cases etc blasting, before rebuilding replacing any parts that are required.
Engine has covered 27,000 Miles.
Cas
Engine Restoration
Engine Restoration
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
1976 KZ1000a1, Red
Re: Engine Restoration
there a number of us who can do this - depends on what needs doing as to costs.
I'm assuming you want someone local.
As I will have to drop off and pick up, would like within 100 miles of LE67.
Although the main objective is cosmetical, I would want worn items replacing.
Would like to discuss scope of work once someone is established.
Past 5 Years
1976 KZ1000a1, Red
1976 KZ1000a1, Red
http://www.aloh.co.uk/
Steve Smethurst does a great job but he is not cheap
I had 2 engines done by him and was really pleased , He does work for Dave Marsden at Z-Power
When a Z1 engine is striped down first things definitely needed are listed below and I brought all them all with the engine
1 x Complete Gasket Set
1 x Cam chain 21070-003 { Non Kawasaki Heavy Duty ones are available costing less than genuine}
2 x Idler Rubber 92075-119
2 x Idler Rubber 92075-120
4 x Rubber Guide Roller 92075-232
1 x Tensioner Assembly 12048-001
1 x Roller 12055-002
2 x Rubber Guide Roller 92075-123
1 x Rod Assembly 12054-001
1 x Spring for Tensioner 92081-107
1 x Guide For Cam Chain 12053-119
I would also consider a new set of piston rings
Zeds-R-Us
Thank you for the information.
Would like a few quotes for comparison
Past 5 Years
1976 KZ1000a1, Red
1976 KZ1000a1, Red
Buzzard,- no worries - 'cost effective'
Buzzards done lots for me .
Buzzworx
Buzzworx
Keefleaf wrote:Buzzard,- no worries - 'cost effective'
Buzzworx
+1. He has a good reputation
PM sent
Past 5 Years
1976 KZ1000a1, Red
1976 KZ1000a1, Red
I may be too late with this reply but i recently used Dave Cunningham at TSR Vapour Blasting. He's in Sevenoaks, Kent but i UPS'd it to him for around £40 from Nottingham. Very impressed with his work, very clean, and very well cleaned out. Cost somewhere between £250 and £300. Can't be certain as he did a few other bits and bobs for me.
Overall, thoroughly recommended.
