Z900a4 rear hub bearing
Can someone tell me the correct depth for the cush side bearing into the housing thanks ☺
Re: Z900a4 rear hub bearing
i dont know the depth but when the bearing is fitted it leaves a space of about 12mm & the sprocket carrier fits into this when both parts are assembled
