Power changes Z1000
scarebus03
Power changes Z1000
#1 PostAuthor: scarebus03 » Wed Aug 23, 2017 2:35 pm
Does anybody know the approximate power increase when using the v&h 4-1 exhaust and wiseco 1045cc big bore kit?
From a restoration point of view the big bore kit was the only practical solution to a seized engine and 4-2 exhausts are like hens teeth. Each of which has to increase power output.
Any ideas?
Re: Power changes Z1000
#2 PostAuthor: Pigford » Wed Aug 23, 2017 3:25 pm
Well set up with 28mm carbs, 80bhp (at the wheel) should be realistic, baring in mind most std bikes are around 65bhp. Add decent carbs, cams and flowed head = +100bhp easy enuff.
scarebus03
#3 PostAuthor: scarebus03 » Wed Aug 23, 2017 3:50 pm
Cheers for that Pigford
