gearbox problem z1 900
- london calling
First thing I would look at , presuming you have checked London's suggestion, is to remove the, sprocket cover and inner cover and check that the 3 or 4 coil spring has not broken or its retaining boss is not damaged. This requires the removal of change lever, front sprocket. Can be a bit of a pain to check If things don't go right.
RegardZ
RegardZ
