17" wheels
angeleddie
17" wheels
#1 PostAuthor: angeleddie » Sun Mar 09, 2008 12:55 pm
Advice needed please.
I have a 1000J which I would like to convert to modern running gear including forks.
The bike currently has a JMC swing arm which I would like to retain. the swing arm would restrict me to a rear tyre width of 160.
Can anyboby advise of a suitable match?
I have been told that suzuki running gear tends to be a little narrower & therefore less complicated to fit.
Finally what problems can be expected with the fitting to the headstock?
Any help appreciated.
Eddie
#2 PostAuthor: Pigford » Sun Mar 09, 2008 1:23 pm
Eddie,
I run a JMC with a GSXR 180 x 17 rear, all you need is an off-set front sprox - Debbens do 'em, and away you go :twisted:
If ur going to go for a fat back-end :?? you may as well GO FOR IT :!:
Most USD forks are a good inch or 2 shorter, thats the first hassle....
If you can get early GSXR USD forks (89-92) they're longer :!:
Then you'll need to get a standard stem fitted to suitable yokes to suit the forks.......
My front end is a complete GSXR USD with matching 120x17 wheel. My yokes are one-off billet items with a staggered arrangement to make up for the shorter forks :|
angeleddie
#3 PostAuthor: angeleddie » Sun Mar 09, 2008 1:38 pm
Thanks for that
I take it you are using GSXR1000 wheels, forks etc.
Also can the GSXR yokes be used? If not can you recommend anybody that can help ?
Thanks again
Eddie
#4 PostAuthor: Pigford » Sun Mar 09, 2008 1:48 pm
Eddie,
GSXR 1100 kit....... pre- 2000 stuff
Checkout the links section above for ideas & yokes, etc. Mine where from a small engineers ooop North, and they swore they'd never do any more, ever again :!: :shock:
Gus has just had some yoke work done quite cheap... he might be able to advise, or PM Jack (London Calling) or Rich :wink:
Padders
#5 PostAuthor: Padders » Sun Mar 09, 2008 1:56 pm
If you want to go modern but still retain the looks i.e no USD forks look at the ZXR750 H1. Front ends can be had complete for ?250.00 inc wheel disc's brakes its a 17 inch wheel etc PLUS has speedo drive. The rear wheel takes a 160 tyre as well so should be ok for your swingarm. Yokes can be made to fit with Zed stem and a spacer although you do loose some steering lock.
padders
london calling
#6 PostAuthor: london calling » Sun Mar 09, 2008 1:58 pm
Eddie,soon I'll be able to lend you a gsxr back wheel,4.5" with a 170/60 tyre fitted,so you check clearaces,etc.
Easiest thing with different forks,yokes,is to use the stem from your current bottom yoke and have it pressed into the GSXR yoke.
Pretty much everything else as the IRON MAN said :wink:
Jack
angeleddie
#7 PostAuthor: angeleddie » Sun Mar 09, 2008 2:12 pm
Thanks Padders/Jack,
I will take you up on that offer when your ready.
I have been offered a complete GSXR750 SRAD front end.
Anyboby know if this will be suitable
Sorry for all the questions but prefer to find out most of the problems firtst
thanks
Keefleaf
#8 PostAuthor: Keefleaf » Sun Mar 09, 2008 3:08 pm
If you want a Zrx 750h1 front end let me know.I`ve got one less mudguard..?200.Any interest give me P.M.
KWACKERZ1
wheels
#9 PostAuthor: KWACKERZ1 » Sun Mar 09, 2008 4:37 pm
Checkout my previous post there some good info in there.
http://www.z1ownersclub.co.uk/forum/vie ... highlight=
Its called what to do with new wheels , in the advice and help section probably about page 8. (just in case the link does not work)
Try not to use suzuki gear as its not right!! izax enginereeing in mansfiled do offset yokes to make up for the lack of length for a usd front end. But for the same price about ?450 maxton will extend usd forks for you.
Bear in mind if you fit usd you will lose turning circle.
I did speak to a guy who fitted zxr400 forks and yokes and wheels into a z1000 and he reckons all he had to do was change the bearings on the stem. (Whereas my zx7r steeering stem is way to fat to take the bearings to fit a z1000 frame.) ZRX1100/1200 fork length is right for a z1000 but I dont kno about the steering stem diameter. A zrx 1100 rear end will fit a z1000 with a new sleeve made up, so could be a quick solution to get a new rear end with big tyre.
I did not pursue fitting new wheels in the end as I have a z1000 with zzr110 forks and yokes and 17"relaced spoked wheels.
Hope this info helps.
Phil
london calling
#10 PostAuthor: london calling » Sun Mar 09, 2008 5:14 pm
Eddie,you might the SRAD front end a little too short and they don't run a speedo drive either.
Most mass produced U.S.D. front ends are heavier than RWU front ends and tend to be very heavy on the front fork oil seals.
I've been told by one of my trade contacts that some of the OHLINS U.S.D. forks get through fork oil seals like a little too often :roll:
Jack
Padders
#11 PostAuthor: Padders » Sun Mar 09, 2008 5:52 pm
Hi Eddie,
Heres a picture of a CB900 I fitted a SRAD front end to. Used a modified laverda speedo drive skimmed to a minimum to fit. Very short so ground clearance was a problem.
Saw this bike again today at Newark with Rich. Apart from a paint job she's just about as I sold her 6 years ago. Small world.
padders
CRISPY
#12 PostAuthor: CRISPY » Sun Mar 09, 2008 6:37 pm
Ive picked up the front and rear end complete wheels brakes etc for 1000 exup for ?300 :up Now just need yokes made had 1 quote but out of my league at min
Jon
#13 PostAuthor: Jon » Wed Mar 12, 2008 9:42 am
Might be able to help out here. :wink: Go onto here;-
http://www.streetfighters-mcc.co.uk/
PM a member called `Yantosh`, and tell him I sent ya. :wink: His work is top notch and his prices are real world! :lol: He`s after some yolks to do at moment anyway as he`s wanting cash to get me to spray his Simpson helmet. :lol: His work was all over the yolks feature in this months Streetfighters mag. Top notch. Give him a try.
kawaman21
#14 PostAuthor: kawaman21 » Wed Mar 12, 2008 1:58 pm
zrx 11 and 12 yokes fit straight into a z1100r frame (just file off bracket on headstock)so should fit a z1000j
you could use suzuki forks in them also :o ,
a sprocket from a 89 zx10 in 530 size is offset enough to work with a 4.5x17 inch wheel,i just reversed the rear sprocket and it lined up,this was with a slingshot swinging arm adapted for twin shocks,and works when i changed it for a zrx arm.i had slingshot forks lengthened but switched to zrx forks.
Jon
#15 PostAuthor: Jon » Fri Mar 14, 2008 9:24 am
Spoke to Yantosh and he said the most he`d charge for yokes is ?350 and thats for top-end stepped 4" things with hidden bolts,etc, etc. Lesser spec would obviously be far less. HTH. :wink:
