Best quality 4=1?
Best quality 4=1?
Can't afford any of the jap bling so looking to get maybe a V&H or Kerker.
If I can get 2nd hand I'd get it coated, but is there an alternative megaphone style exhaust that's better quality as I've heard both of the above are not particularly well finished.
Re: Best quality 4=1?
http://www.ebay.co.uk/itm/4-1-Exhaust-S ... Sw2GlXGPOp
Just put one of these on my Gpz and must say its pretty good value for money and sounds good too...
paid up member
Julian_Boolean
Kerker is a lot of money for what it is, I wasn't impressed with the one that came on my bike, Vance and Hines is cheaper and better made, depends what you want though, you can get a repro Harris, hopefully better made than the originals.
Delkevic all the way, two styles, stainless and come with all that's needed and just under £300, have one on my 350/4 also had one on my xs650.
Used Delkevic recently ,stainless steel,well made,picked up from stockist,Dk,s....£250 cash.
The Delkavic is certainly great value for money, the cone doesn't look quite right though.
As has been said the kerker is very poor value for money - but the looks are spot on. If you like the look of the Kerver then what about the Marshall Deeptone, which is pretty much clone of the Kerver (except with removable downpipes). I have one I'm going to use on one of my projects.
https://www.ajsutton.co.uk/product/lase ... ares?uID=0
Or the Eagle Classic is similar to the Kerkar also:
https://www.cobraexhaust.de/Eagle-Class ... 00-1976-77
I know its not the megaphone type but this is what I intend to fit to my Z1R
http://www.ebay.co.uk/itm/Full-4-1-Exha ... 1438.l2649
Thinking of getting a Kerker style megaphone made in stainless....obviously if I can get a batch done it will be cheaper.
Have put feelers out already but can't give any definites at the moment.
Any positive comments...or is it a bad idea?
Haggler wrote:I know its not the megaphone type but this is what I intend to fit to my Z1R
Just put one of these on my J and it's great.
Looks good n makes a great noise
Only negative was that the collars on the headers barely left enough of the cylinder head studs to thread the nuts on fully, but it's fine once re-torqued a few times.
H2B GPZ900R
Julian_Boolean
rickm wrote:Haggler wrote:I know its not the megaphone type but this is what I intend to fit to my Z1R
Looks good n makes a great noise![]()
What diameter are the down pipes?
Julian_Boolean wrote:What diameter are the down pipes?
External diameter is 35mm (half-way down the down-pipe).
H2B GPZ900R
Just put one of the Delkevic 4-1’s on my z900.
Only thing is the kickstand now wants to whack against the frame when it goes back. They do supply a bracket with the exhaust but it looks like that’s for the main stand.
This can’t be a new problem I’m guessing ? What d’ya do ?
1975-S1C wrote:Just put one of the Delkevic 4-1’s on my z900.
Your stand should not do that, there is a lot of us with 4into 1's and don't have that problem, is your stand bent or is the wrong one for the bike?
Ah oK, that makes sense.
Not sure if it’s the right stand as it was on the when I got the bike. I did think the bike leans a bit heavily over to the left on the kickstand. Maybe that’s why then.
Guess I better check and see about getting a new one.
could be an LTD side stand ?
Users browsing this forum: Google [Bot] and 59 guests
