Oil level
AlanB
Oil level
#1 PostAuthor: AlanB » Mon Sep 25, 2017 5:17 pm
Recently changed oil and filter with 3.7Ltr then ran the bike round the block - Came back and left bike for half an hour or so checked level and oil was just below max Mark so ok - Next day level shows over max Mark - So is this normal and are you only supposed to check after running the engine and leaving to settle for a while ? It does have an oil cooler with pipes attached below cooler - Cheers. :blah
Re: Oil level
#2 PostAuthor: z1bman » Mon Sep 25, 2017 5:29 pm
its best to check the level when the engine is stone cold especially if it has an oil cooler
