Guys. I'm after the large hexagon drain screw cap from a Mikuni float bowl for a HSR42, though I'm pretty sure it's exactly the same as fitted to Z1's and smoothbores.
I want to make a float height tool adapter (with clear tube) so I can see the actual level.
Does anyone either have a spare, have one they can lend to me, or are these available to buy?
Thanks Will
Mikuni HSR carb bowl drain screw/cap
- Attachments
- images.jpg (8.41 KiB) Viewed 1891 times
- paul doran
Re: Mikuni HSR carb bowl drain screw/cap
Will I have a float height tool I can loan to copy I can bring to Stafford if that suits
paul doran wrote:Will I have a float height tool I can loan to copy I can bring to Stafford if that suits
That would be ideal, thanks Paul.
I'll be there Saturday morning and will track you down on the stand.
- paul doran
