Hi,
I’m rebuild/moding a Z1000A1, I bought a head off Padders which I think he said was off a MkII? It has some extra “clean air”? holes that are exposed when I fit the A1cam cover. Can anyone explain what they do and whether they are supposed to be covered or open?
Cheers Russ
Head difference
Head difference
Z650C2, B1, F1, ZX9R, Z1000A1
Re: Head difference
Just block them off - they're no use.... only fitted to me USA emissions.
Re: Head difference
Just tap them and plug with Loctited grub screws , works fine for me
0172 . Geoff Parr
Re: Head difference
Or use cover with tabs to cover the holes.
Re: Head difference
I'm confused again. My bike has a mk11 engine, cam cover has little top things that look like they should connect to something that should run up the outside of cylinders. There is nothing though that runs up,the cylinders. Not had cover off yet so no idea what's in there.
Ian.
Ian.
Re: Head difference
ianali wrote:I'm confused again. My bike has a mk11 engine, cam cover has little top things that look like they should connect to something that should run up the outside of cylinders. There is nothing though that runs up,the cylinders. Not had cover off yet so no idea what's in there.
Ian.
You probably have a non emissions cover for the US market.
Re: Head difference
Hi ianali
in the US in the early eighties of the previous century they worried about emission.
Kawasaki came up with the idea to add fresh air to the exhaust gasses in order to get them cleaner and to be able to meet the US regulations so they could continue selling bikes in the US.
There was a tube coming with a valve connected to it from the air filter body that split into two tubes, these went to each side of the camshaft cover.
In the camshaft cover there was a membrane that opened due to underpressure when the exhaust gasses left the engine. The air was sucked through the holes in the cilinderhead and came out near the exhaust valves thus enabling clean air to be mixed with the exhaust gasses and causing some sort of "afterburner" .
This device was not required for the other markets.
So you have a US cilinderhead and camshaft cover for an MK2 or an ST (similar cilinderheads)
Plug the holes in a descent way and you'll be able to ride your bike.
Good luck !!!
Greetings from Belgium
Good luck !!!
