earth wire outer.
ianali
earth wire outer.
#1 PostAuthor: ianali » Tue Nov 21, 2017 1:15 pm
Just going over my bike cleanIng up and checking wiring. All pretty good apart from one earth wire that has lost an inch or so of its coating. The wire itself is good and shows no sign of damage. It is the earth that goes into a 6 pin connector running into the regulator. Dare I hope that the damage is just age related and re wrap the wire or should I worry more? Bike runs perfectly.
Thanks,
Ian.
Re: earth wire outer.
#2 PostAuthor: Pigford » Tue Nov 21, 2017 1:51 pm
if it "runs perfectly", don't worry, just redo that bit of insulation & check connection for corrosion & security.... sorted.
ianali
#3 PostAuthor: ianali » Tue Nov 21, 2017 2:02 pm
Thanks.
Ian.
KeithZ1R
#4 PostAuthor: KeithZ1R » Tue Nov 21, 2017 4:04 pm
wot Piggy sed and if your carefull you can tease the connector out of the socket and get some heat shrink sleeve on it maybe
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Users browsing this forum: No registered users and 77 guests
