Z1B
Scubakawa
Z1B
#1 PostAuthor: Scubakawa » Sun Nov 26, 2017 4:51 pm
Hi just joined from Aberdare South Wales had my Z since 1976. Hasn't been started since 1990. Have recently fitted high compression 10.25 to 1 pistons 1045ccAction Fours which iv'e had since1990. Has high lift cams fitted in 1977. Have fitted new rings and bores honed, new coils, new Boyer Bransden ignition new hard plugs which were recommended in 1977. Carbs been cleaned large jets fitted in 1997 Spark looks good plugs wet. Can I start it!! no chance It just doesn't want to know. Have had bikes all my life beaten me. Anybody know someone in South Wales who will look at it?
PAULJAC47
Re: Z1B
#2 PostAuthor: PAULJAC47 » Sun Nov 26, 2017 6:03 pm
:shock: :shock: :shock: :shock: No rush then?
Put some basics up chap,compression test,cam timing,ignition timing etc....
Taffus
Re: Z1B
#3 PostAuthor: Taffus » Sun Nov 26, 2017 8:10 pm
Contact Steve Bowdler, he's your area rep and has good contacts in the south wales area
engz1b
Re: Z1B
#4 PostAuthor: engz1b » Mon Nov 27, 2017 3:02 pm
hi try andys mobile motorcycle mechanic, based in swansea 07450 936157
Re: Z1B
#5 PostAuthor: z1bman » Mon Nov 27, 2017 4:33 pm
check the valve timing & compressions
Re: Z1B
#6 PostAuthor: ADRIAN H » Tue Nov 28, 2017 9:34 am
Valve / Ignition timing ?
Scubakawa
Re: Z1B
#7 PostAuthor: Scubakawa » Tue Nov 28, 2017 6:22 pm
Valve timing 28pins compression good bad memory not sure if high lift cams had different number of pins been 40 years mind and no literature away at. Moment i will try those numbers when I get home. Many thanks to all replies
ColSZ1B
Re: Z1B
#8 PostAuthor: ColSZ1B » Wed Jan 03, 2018 9:40 pm
Don't know if he's still around but try Steve Tucker 01495 216394. Was big into Zeds at one time. No harm in a fone call. Abertillery I think . Colin S.
ColSZ1B
Re: Z1B
#9 PostAuthor: ColSZ1B » Wed Jan 03, 2018 10:26 pm
How big did u go with ur jets mate .
Re: Z1B
#10 PostAuthor: chrisNI » Wed Jan 03, 2018 11:00 pm
When did it last run? If the plugs are wet and it sparks it should at least fart... all this is assuming the cams are timed right. One would also hope there has been no fuel in it since the carbs were cleaned... also they don’t always clean first time. Have you tried new plugs?
Taffus
Re: Z1B
#11 PostAuthor: Taffus » Thu Jan 04, 2018 12:20 am
chrisNI wrote:When did it last run? If the plugs are wet and it sparks it should at least fart... all this is assuming the cams are timed right. One would also hope there has been no fuel in it since the carbs were cleaned... also they don’t always clean first time. Have you tried new plugs?
I don't know why but my first thought was this is how to get sense from Hobbo.......
Re: Z1B
#12 PostAuthor: ZedHead » Thu Jan 04, 2018 9:35 am
Basics first, if you have a good spark as you say try removing the air filter, if it has one, and spraying easy start in the throat. If it runs on that you know you have a fuel problem.
ColSZ1B
Re: Z1B
#13 PostAuthor: ColSZ1B » Thu Jan 04, 2018 9:54 am
ZedHead wrote:Basics first, if you have a good spark as you say try removing the air filter, if it has one, and spraying easy start in the throat. If it runs on that you know you have a fuel problem.
+1
Re: Z1B
#14 PostAuthor: z1bman » Thu Jan 04, 2018 12:30 pm
if it has a good spark & is getting fuel it should at least attempt to fire. it may be down to it firing in the wrong place or valve timing is incorrectly set a compression test should determine if the valve timing is out & put a strobe light on it whilst turning it over will give some indication if its firing in the correct order
wayno
Re: Z1B
#15 PostAuthor: wayno » Thu Jan 04, 2018 4:42 pm
Could the coils on the wrong plugs cause this? 1+4 on 2+3?
