Z1a Headlight Shell
BigZCas
Z1a Headlight Shell
#1 PostAuthor: BigZCas » Thu Nov 30, 2017 7:11 pm
Would you believe it !
After finally getting hold of a replacement headlight shell to replace a damaged one that was on the bike, the blaster has gone and blasted of the lip at the top that holds the rim on :evil:
Only noticed tonight when I went to fit the headlight (tried hammering).
So after having 2 powder coated I am now after another :(
Anyone got a good condition shell please, Stanley 001-0799 that they are willing to sell ?
Paint not a problem as I will powder.
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
000zeds
Re: Z1a Headlight Shell
#2 PostAuthor: 000zeds » Thu Nov 30, 2017 8:12 pm
Try John Browse 01978 355556
Zeds-R-Us
8 Valve Mark
#3 PostAuthor: 8 Valve Mark » Thu Nov 30, 2017 8:48 pm
hi Cas,I've got a good solid chrome one up my sleeve. originally from the u.s. i believe cos it has a wee hole at 12 o'clock for an idiot light..it has a coupla wee dings n grazes n surface rust on the inside but properly prepped for powder/paint will be spot on.clearly stamped 'stanley 001-0799 Japan' rim is 100%
8 Valve Mark
#4 PostAuthor: 8 Valve Mark » Fri Dec 01, 2017 8:46 pm
thanks for the pm Cas I'm glad you got sorted.anyone else needing one?..
