z1,a,b and a4 swing arms all the same?
glav666
#1 PostAuthor: glav666 » Thu Nov 30, 2017 11:38 pm
I need a swing arm for my z900a4 rebuild are they the same as the z1, a and b as I have sourced one oil the states???
Thanks in advance
8 Valve Mark
Re: z1,a,b and a4 swing arms all the same?
#2 PostAuthor: 8 Valve Mark » Fri Dec 01, 2017 12:55 am
as far as i know they're all suitable..also.a z1000 s/arm is easy to convert for a 900 by grinding off its top mounted, brake stabilising bracket (for disc brake) and welding in 2 basic 'D' brackets
to attach the drum brake torsion arm for z1-z9..much easier n cheaper than importin from the u.s.of trump!! i also have a z1000 arm i could let you have if you go that route.. let's know. mark
glav666
#3 PostAuthor: glav666 » Fri Dec 01, 2017 8:26 am
8 Valve Mark wrote:as far as i know they're all suitable..also.a z1000 s/arm is easy to convert for a 900 by grinding off its top mounted, brake stabilising bracket (for disc brake) and welding in 2 basic 'D' brackets
Great tip Mark Thanks, thats why I love this forum.
PM sent
8 Valve Mark
#4 PostAuthor: 8 Valve Mark » Fri Dec 01, 2017 3:11 pm
if there are any pitfalls I'm sure someone will know on here..my late mate converted a z1000 arm for his z1b yrs ago.
chrisw1
#5 PostAuthor: chrisw1 » Fri Dec 01, 2017 6:20 pm
basically they are the same .... there is some cosmetic difference to the earlier arms up to 75 as they have a narrower crinkled look to the arm above the chain adjuster .........and of course the date code for the purists
Users browsing this forum: Google [Bot] and 59 guests
