SOLD Adjustable black TEC shocks dry build use only
For sale a pair of adjustable TEC shocks I used for the dry build part of my Z1 build. I have a set of Ohlins Black Line shocks on the way (xmas prezzie) so these are now spare. Without the extension part they are 335mm eye to eye with the extensions 365mm eye to eye. You can get a 15mm extension from TEC if you want to run standard 350mm height. I have addded a couple of pictures as fitted for dry build. With having the shock mount moved forward and using a ZRX swingarm I was unsure of the length needed. Looking for £75.00 collected £85.00 posted UK
PUM 13
- ZedHead
Re: Adjustable black TEC shocks dry build use only
Yes please Padders.
PM about to be sent.
Cheers,
Mark.
Mark.
