Z650 carb parts
Gus
Z650 carb parts
#1 PostAuthor: Gus » Fri Dec 29, 2017 6:52 pm
Evening Gents.
I bought a set of Z650 carbs from a genuine seller but to both of our dismay when I opened the float bowls there were no bleed tubes, O rings or main jets in them.
Items 26, 16047-005 PIPE,BLEED, 27 and 28.
This Kawasaki 16047-005 PIPE,BLEED Not Available fits the following models and components:
Kawasaki Motorcycle 1977 Custom - KZ650-C1 Carburetor, Parts
Kawasaki Motorcycle 1977 KZ650-B1 Carburetor, Parts
Kawasaki Motorcycle 1978 Custom - KZ650-C2 Carburetor, Parts
Kawasaki Motorcycle 1978 KZ650-B2 Carburetor, Parts
Kawasaki Motorcycle 1978 SR - KZ650-D1A Carburetor, Parts
Kawasaki Motorcycle 1978 KZ650-B2A Carburetor, Parts
Kawasaki Motorcycle 1978 SR - KZ650-D1 Carburetor, Parts
Kawasaki Motorcycle 1979 Custom - KZ650-C3 Carburetor, Parts
Kawasaki Motorcycle 1979 KZ650-B3 Carburetor, Parts
Kawasaki Motorcycle 1979 SR - KZ650-D2 Carburetor, Parts
Kawasaki Motorcycle 1980 KZ650-F1 Carburetor, Parts
Kawasaki Motorcycle 1981 CSR - KZ650-H1 CARBURETOR PARTS (KZ650-H1)
Kawasaki Motorcycle 1982 CSR - KZ650-H2 CARBURETOR PARTS (KZ650-H1)
Kawasaki Motorcycle 1983 CSR - KZ650-H3 CARBURETOR PARTS (KZ650-H1)
Does any body have a duff set of carbs that I could have these parts from or at the least the bleed pipes as they are no longer available?
Thanks in advance
Gus
"Set the GRINDER on it"
Re: Z650 carb parts
#2 PostAuthor: z1bman » Fri Dec 29, 2017 7:49 pm
Gus
Re: Z650 carb parts
#3 PostAuthor: Gus » Fri Dec 29, 2017 7:51 pm
Thanks for the link.
Already watching :D
Gus
Spen72
Re: Z650 carb parts
#4 PostAuthor: Spen72 » Sat Dec 30, 2017 4:59 am
Hi there I have a set of z650 carbs that look all there..Spen
Gus
Re: Z650 carb parts
#5 PostAuthor: Gus » Mon Jan 01, 2018 2:25 pm
Hi Spen.
I sent an email and PM to you but no reply as yet.
Gus
Gus
Re: Z650 carb parts
#6 PostAuthor: Gus » Thu Jan 04, 2018 1:43 pm
Hi Spen.
Is there a point to your post?
Gus
big green bus
Re: Z650 carb parts
#7 PostAuthor: big green bus » Thu Jan 11, 2018 5:04 pm
Did you get sorted?
Gus
Re: Z650 carb parts
#8 PostAuthor: Gus » Thu Jan 11, 2018 5:33 pm
Hi BGB
Not yet as an unexpected bill arrived and I was unable to bid for the spares and looking at the 2 bids it seemed I would not have got them for the starting price.
Cheers for now.
Gus
