Master cylinder plastic level window
Mr Bump
#1 PostAuthor: Mr Bump » Mon Jan 01, 2018 6:33 pm
Evening all,
Is it possible to get hold of a plastic level window for a gpz1100 anywhere? Mines all crazed and looks like it’s weeping a little.
Thanks,
Olly
Lemmy
Re: Master cylinder plastic level window
#2 PostAuthor: z1bman » Mon Jan 01, 2018 10:34 pm
#3 PostAuthor: z1bman » Mon Jan 01, 2018 10:45 pm
some of the oil spy glasses on kawasakis are the same
Mr Bump
#4 PostAuthor: Mr Bump » Tue Jan 02, 2018 9:01 pm
[quote="z1bman"]what size is the one fitted ?
Its a big one, about 23 mm. Most ones listed seem to be 10 or 18 mm.
Cheers, Olly.
Lemmy
#5 PostAuthor: z1bman » Tue Jan 02, 2018 9:16 pm
have you measured yours ? this one is 25 mm outside diameter 52005-1009
https://www.ebay.co.uk/i/332317148176?c ... 912&crdt=0
Mr Bump
#6 PostAuthor: Mr Bump » Thu Jan 04, 2018 10:23 am
Hello mister,
Had another look last night and pulled the master cylinder apart.
The aperture in the m/cyl casting is definitely 23mm, there’s an O ring in there too. As luck would have it i had a scrap gpz1100 clutch cover kicking abou with a sight glass in it which I’m pretty sure is the 1009 sight glass you’ve identified. If I cut the seal off around the outside of the glass the metal remaining looks like it’s a press fit in the m/cly casting.
Sealing may or may not work, the rear face of the seal which wouldn’t need cutting off would butt up against the back of the aperture, so with a bit of sealant it might work.
The 1009 seal is only a £10 or so, so I’ll probably buy one and give it a go.
I’m a bit surprised there isn’t a solution out there as I can’t imagine it’s a very rare failure (?).
I’ll let you know if it can be made to work.
Olly
Lemmy
Mr Bump
#7 PostAuthor: Mr Bump » Mon Jan 08, 2018 9:12 am
Nope, won’t work. With the rubber cut off it’s still too tight a fit, so ultimately the glass cracks.
Has anyone any ideas or advice please? I don’t really want to have to replace the whole master cylinder if I can help it.
If I do end up needing another one, does anyone have a suitable gpz1100b / z1000j master cylinder for sale, or is there an alternative or upgrade that works well?
Thanks,
Olly
Lemmy
Users browsing this forum: Google [Bot] and 106 guests
