Box Section Swingarm wanted
dynodave
#1 PostAuthor: dynodave » Fri Jan 12, 2018 11:15 am
I need a steel box section swingarm for my Triton project, has any body got anything? I think a Radian one may fit. It needs to be relatively short and twin shock compatible. Dimensions are roughly:
swingarm pivot to wheel spindle 370 - 425mm ish
inner faces at rear 240 - 265mm ish
inner shock mount faces 265mm
pivot faces are 276mm so anything less than that would be ok.
Dave
KWACKERZ1
Re: Box Section Swingarm wanted
#2 PostAuthor: KWACKERZ1 » Fri Jan 12, 2018 7:57 pm
Hi mate hope you are well still tinkering! :D :D :D :D
Have texted you.
