Few Zed Bits
Few Zed Bits
Having a bit of a clearout ,all chrome bits are servicable but chrome dull/pitted bar the clock covers which seem good.all prices plus p&p at cost.
35t rear sprockets look new! £12.50 each
idiot light covers v good £25 for both will seperate
Kick £15
Gear lever £7.50
Spindles re zinced a4 i think £15 each,rear one with the adjusters £20.
Clock covers £10
Oil Pump from working engine £25 comes with seal to link to engine intake and bolts.
Mc £20 reckon will need rebuild.
Stator meters out fine across windings,though no plug £20.
Starter motor Cover £7.50
Fuel cap with key,needs new seal some pitting £10
speedo drive £15
cable guide £7.50
I also have a number of engine valves /springs probably enough to do on engine at least all from working engines plus a quantity of brake calipers z thou etc and parts plus a have a number of fuel taps including a black Z1 tap with the rubber insert thingy,unknown nick may be ok for bits that i will be listing shortly..Happy to discuss any item..Cheers Paul J
Re: Few Zed Bits
Hi Phil
I need a set of adjusters / kickstart and gear lever please .....
Re: Few Zed Bits
Hi Chris,do you want the whole rear spindle with the adjusters? i may have a pair of re zinced adjusters? can check tommorow...Paul J
Re: Few Zed Bits
Just checked,only have one good spare adjuster the other has lost some of the re zincing has no bolt or inner nut.
Re: Few Zed Bits
Could I grab the clock covers off you and the centre console idiot lights,
Would also like the swing arm pivot if its availabll and If you have some spare re-zinced adjusters I would be interested in those.
Re: Few Zed Bits
Hi Only have one complete re zinced adjuster,the other has lost some of the re zinc and has no captive nut or bolt,just waiting on Chris,s response re the other adjusters on the pics Thanks.Will reserve covers and spindle and covers no nut with the spindle, do you want upper and lower idiot light covers?..Paul J
Re: Few Zed Bits
Hi Paul .....I only need the adjusters really if someone else needs a spindle but if they come as a package that's fine
Re: Few Zed Bits
Just a thought .is the m/cl for twin disc ?
Re: Few Zed Bits
Chris pretty sure thats a single disc Mc,could be bored to suit though if you dont need the spindle ,£10 buys the adjusters.would cost a bit more to send something you dont need.Pm me with your contact details and will let you know the cost of the items and paypal details..Thanks Paul j
Re: Few Zed Bits
Is the idiot light and back cover, and clock back covers still available? Will take them all if available..
Re: Few Zed Bits
Have had interest in all those items i am afraid,but if sale does not go through will give you a shout .Cheers Paul J
Re: Few more Zed Bits
Having a bit of a clearout ,all chrome bits are servicable but chrome dull/pitted but good.all prices plus p&p at cost.
z1000 rear brake pedal £15
2 Spindles re zinced a4 front i think, £15 each,rear one with out the adjusters £15.....adjuster re zinced one still available £5
Mc front single Tokico with lever £20 reckon will need rebuild.
Kz1000 badges good £15 pair
speedo drive £15
cable guide £7.50
A4/thou fuel cap with key,new seal, few scratches £12.50
Large selection,valves,springs,cam caps etc, available in addition.
Pair excellent thou a2 calipers stripped ready for paint,need seals,pistons etc..£75
Single lh thou caliper bracket and caliper only,, good nick £30
Gs thou complete caliper,needs rebuild £20
Away for a week from this Fri 17th so will not see ant Pms till return
Will bundle and take offers...Cheers Paul J
speedo drive £15
cable guide £7.50
Re: Few Zed Bits
Parts purchased in post today(Wed)...Paul J
Users browsing this forum: Google [Bot] and 37 guests
