Z1000J/GPz1100 bits for sale
Afternoon all,
I'm having a bit of a clearout of the garage and so have a few bits up for sale. The wheels are probably too big and heavy to post, but if necessary I'll see what I can do. Otherwise postage would be at cost.
GPz1100 rear wheel (18x2.50) with a usable Avon Roadrider tyre (the gold one). The powder coating is lifting in places but otherwise it's in reasonable condition. The disc has a couple of minor cracks. This wheel is a good upgrade for a J. £100.
A pair of standard Z1000J wheels (front 19x1.85, rear 18x2.15) - the black and silver wheels. The front discs are worn, the rear has no disc. The tyres are probably just about legal but are quite old. Otherwise, the wheels are in pretty good condition. £100 the pair, may split (cush drive rubber and speedo drive not included).
A pair of J front calipers for rebuild (maybe the same as GPz1100B?), though worked ok the last time I used them. £100 the pair + post.
1no. Z1000J sprocket carrier (again, possibly the same as GPz1000B?). The sprocket isn't brilliant and I haven't checked the bearing or seal. £15 plus £7 postage.
Stock Z1000J swinging arm (again, probably same as GPz1100B). Good condition. £80 + post.
Z1000J rear caliper for rebuild (worked fine last time I used it). Complete with bracket and torque arm. £50 + post.
Re: Z1000J/GPz1100 bits for sale
Z1000J (rare) rear light bracket. It has small repairs to the indicator mounts but you wouldn't see these when fitted. Needs paint. £60 + post.
Progressive Suspension rear shocks. 360mm between centres and generally in good condition. The damper rods are good and don't appear to be leaking. The rubber bushes are a little cracked and the bottom steel bushes are home made (not my doing). £100 + post.
I may have other chassis bits kicking about so if you need anything specific please just ask.
Offers considered on all parts.
Would you have the plastic chain guard available?
GPZ1100 B2 owner
GPz 305 project
99% Gpz1100 unitrac Nearly there runs just needs paint.
1100 Zephyr Project.
1981 KZ1000 LTD
GPz 305 project
1981 KZ1000 LTD
1962royp wrote:Would you have the plastic chain guard available?
I might just Roy. I'll have a look in the morning.
Chain guard sold.
Pauldonjuan
- Regular Poster
Do you happen to have an exhaust system?
Pauldonjuan wrote:Do you happen to have an exhaust system?
I have an old chrome 4-1 of unknown branding. It's definitely not a Kerker...
Pauldonjuan
- Regular Poster
Is it a quiet one? How much are you wanting?
Regards.
Regards.
Pauldonjuan wrote:Is it a quiet one? How much are you wanting?
Regards.
It's not Motad quiet but it's not deafening. I hadn't really thought about selling it until you asked so I hadn't thought of a price. Make me an offer?
Chainguard sold.
Is the rear mudguard and inner for sale
Will27 wrote:Is the rear mudguard and inner for sale
No, sorry. Those bits are staying.
Chain guard bracket sold. Offers welcomed on any other bits.
I could use the chain adjusters.
P.M. On way
P.M. On way
Keefleaf wrote:I could use the chain adjusters.
P.M. On way
I still have them so just let me know.
